silverstreakNZ
i plan to stick with the vm44 when i rebuild the cr500 . will prolly make a carb wing . on the air box side
bike currently has a #2 slide . however i see vmx/cycleworld rekons a #3 was the go .
only other mods are boyesen reeds and the muffler is slightly bigger bore .
bout 20 deg and sealevel riding . bp 98 and maxima full synthetic at 40/1
the bike would kickstart if it had to and i thought it ran alright .
the chrome is worn off the slide currently so ill prolly replace the whole carb
also is it possible to tune a 2 stroke with a wideband 02 sensor in the exhaust ? as i have one and could back pack a battery etc . what ratio would you aim for ? 12.5 /13 :1 ? or os that too lean ?
