82.5 cr500 has a decompressor port in barrel
silverstreakNZ
has anyone seen a barrel with a decompressor port like this ? i assumed it was standard but looking into it further i think its not . its always just had a capped off spark plug in it and i could kick start the bike on most occasions but the piston was fairly tired so now i'm rebuilding it im going to fit a victa auto decompressor to it
oh maybe i should have clarified . i was more asking has anyone seen a STOCK barrel with the decomp port in it ? on a cr500 .
i considered the small button decompressors too but ive heard on a big enough bike getting kicked hard enough they close before it actually fires . they prolly work quite well if it is only a small hole drilled into the chamber . with the victa decompressor i can change the springs in it untill it works as it should .
those small blue ones are also used in big inch harley motors. they put them right in the head.
yeah i see they have full stainless versions of the lil blue ones for harleys . might try that too . rather have one of them than the big diaphram one which is actually quite ugly and naturally open
I used one of these in the head of my 1981 430 CR and it works great!
You can see it in the vintage restoration section under 1981 430 CR resto-mod.
The pictures of your cylinder dont look like it was stock. I would assume if Husky did that it would have a cast void in the fins with a boss for the valve instead of it clearly being machined away. Looks like user modification to me, but a good one nonetheless. On my Maico's and KTMs that have them, the hole is not the size of the valve like yours, they have a tiny hole in the sleeve like the one in visiteur1948's picture.
