'84 Husky 500 Frame - Good Candidate for TT500 motor?
hawaii-rider
I have an 84 frame I was going to swap out my 500 XC motor into (my 83) but have always wanted to build a Vintage racer four stroke
forget finding a TE510 of the period....yikes...and i have found some solid low miles TT motors.
Anyone do the franken bike with the 84?
I picked it due to the head angle over the 83, so the girl will turn....
Ideas?
warnings?
Cautions?
Thanx
HR
It has been covered pretty thouroughly perhaps six or more months ago.
edit later, putting an air cooled 510 motor into the white dual shock two stroke frame is what was covered. It seems I typed too soon.
Try the search function. I have the 88 water cooled one and it doesn't intrest me just seems the radiators are bigger for the four stroke bikes and there are less fins on the four stroke bikes air cooled, something doesn't compute. If I recall you need the engine or at least the head from a dual shock one as carb location isn't the same even though they both are air cooled.
fran
I have ridden a tt in a 84 frame, not bad, but the bottom cradle needs to be dropped a bit. probably turns better than my my 510, as its heavier and pushes the front.
A friend with a hot tt motor in a maico 81 frame rode my 510 and thought the 510 felt a lot "lighter" which i wouldnt disagree with. his motor has no flywheelwith a battery ignition etc.
I came off the 81 maicos to the 510 and I think you can say you steer the maicos with the front wheel and the 510 from the back wheel.
Ideas?
warnings?
Cautions?
Thanx
HR
The cradle is too short on frames after 1982. I checked an 83 CR frame and found the cradle tubes would need to be stretched almost 2" to get a good fit
But they take up to 90% power increases and remain reliable
I was not being Nasty, they are 100% bullet proof, but SO heavy, all the weight is high up too, which makes it worse.
Mine had a free flow pipe, larger, jetted carb and open air cleaner, cam and it did go, hard, but did not turn or stop, it was like a dog on wet floor boards, fun but not fast.
well, maybe there was a reason the four strokes of the period just didnt work...and...Im ANTI top heavy weight bikes....
hey, its winter...looking for a project----
guess I will keep looking!
its okay I have TIME...
Thanx everyone....awesome feedback!
HR
dont rule them out - they are a lot of fun, and racing in 4 stroke vintage class is even better.
I built this one form a klx frame and honda xl 500 motor with yamaha 43mm front end. It took a lot of time but cost very little - but then i rode a 510 and it blew me away ! - sold this one below straight away and poured a ton of money into a wreck of a 510 (try find a cheap head!!) - worth it ?- absolutely! I was a die hard maico guy and husky virgin until then , but i always wanted to try a 4 stroke for fun- the 510 will hold its own amongst the 2 strokes but as always 95%rider..the 510 is all about the motor..they are out there just depends how bad you want one! the motor just rocks in standard form compared to a xl or tt in standard form.
this is all you need all you need!
jeffs bike in the flesh. a watercooled twinshock frame with a shortenend and modified 86 swing arm
great fun and id say its turns better than my 510..why? 85 steering head angle, lower mass and heavier engine? another one built for not a huge amount of money..
Cool bike as all these specials are...
wow...what an awesome build.....
love it....
what tank is that?
old 125 YZ?
started with an 85 frame?
86 swing arm?
any frame cutting to get her to fit?
HR
er ...correction an 84 l/c frame , yes a yz 125 tank and the cradle is about 2" lower than standard, i think!!
That is the main reason TT500 engines are transplanted. One guy in Australia did an article on how to make the stock frame handle like a maico while still weighing in at 280 lb. Someone else transpanted one into a Maico frame and still waiting to see if he finishes it
