85 CR 500 gear box-help needed
speedyauto
My bike shifts fine for 10 mins then looses spring tension & I have to remove the clutch cover & find the shift spring has come adrift from where it needs to be then I have to put the shift spring back in it's place.
Has anyone else had this problem?
How do I fix this?
Where can I buy a new spring?
Thanks.:cheers:
The return spring is on the under side of the shift link arm.
In the pic it is on the bottom so can't see if it's bent.
Later George
Later George
Yep the 1 I'm having trouble with is the on that is hidden in the above photo.
It seems to want to jump off from the locator.
Speedy.
Flip it over and take a pic I can tell if thats your problem from a pic with just the way it is.
Later George
The spring in question seems to be bending out of shape.
I've bent it back into shape after looking at some pics my mate sent of his but the fact that it's bending would suggest to me that it's stuffed & lost its spring tension.
does anyone know where I can buy a brand new 1 or is second hand the only option?
Thanks,
Speedy
How do I fix this?
Thanks.:cheers:
Sounds like gear selecter spring #31 part# 1611 692-01 , try www.huskydoggg.com $8.00 + p&h or www.husqvarna-parts .com $22.00 +p&h.
