86 400 Oil Leak
maddog82
I think the clutch cover gasket is leaking. Any tips on removing the clutch cover? Anywhere else it could be leaking?
If the level is high enough it can come out a little bleed hole under the water pump. I think the only real seal there is the seal in the bearing for the water pump. The seal for the water doesn't seal the oil if I recall correctly. What I see in your picture is the gas tank for an 85-86 and the kick starter for an 87-88. I can't make out the kind of kick start rubber bumper to determine if the clutch cover matches the kick starter or the frame and tank in vintage. I usually thread a bolt into one of the water pump bolt holes after taking off the water pump and pull on that and the kick starter, the locating pins for that cover can make a bit of force necessary. I generally glue or gasket cement the gasket to the cover and hope it doesn't stick to the case so it can be re used multiple times.
It could be leaking out the shifter hole (which will have a steel sleeve if it is the 87-88 clutch cover again if I recall correctly) there is one or more o rings there I think.
fran
That is the 87-88 rubber kick start bumper and hence the whole cover. If/when you take the cover off and see six clutch springs then the whole engine is 87-88. The 85-86 should have a little piece around the sprocket shaft with four small machine screws. If it has no such removable plate they the whole engine is 87-88. Of course you could check the number as well on the case. Just from what I have dis assembled and the parts sheets I have studied.
Fran
