Hello,
I need to figure out why there are just 2 wires hanging out of the magneto harness just chillin.
I tried to search but can't find anything related to what's coming out of the magneto. So the Green and white wires are what's confusing me.
blue and black go to the coil the yellow goes to lighting, those seem normal. They kill switch has a 2 wire setup, I'm pretty sure the blue is supposed to go to it right?
What really makes me mad is that local laws have changed, I picked it up since I could go on trails with the thing for fun, but law states that they have to be licensed to go on trails yet you can have just an orv sticker and ride on the shoulder. (used to be the other way around) So I'm in the process of trying to make it street legal. Im not looking forward to getting a title issued... I plan to run the lights, horn, and trailtech speedo off a battery and have the magneto lighting coil just as a back up via switch to the lights in case the battery dies (don't ever plan to ride this at night). So thoughts on how to hook up a rear brake light switch?
Carb, is there any tuning advice besides air/ratio needle 1.5 turns out? the few times I was able to get it running it, had to be >80ºF out and required full choke and 1/8th throttle to stay running. Although when I rolled it down the street I did a surprise wheelie in 3rd) I have spend hours cleaning and adjusting it reading about it online. Also, I have cleaned the float slider rods very well, but it does this cute thing and leaks gas out the over flows for about 4 seconds after turning the gas on. Thoughts? There is a dyno place near buy that says they will tune and jet it for about $320 out the door, but I don't want to spend anything more on this (poor college student) Also, I'm not even sure how much life this engine has. Seems to have good compression but that's all I can tell you.
Side note question, how easy is it to straighten out a spoked rim on one of these?
Thanks for any input!
(poor quality pics to illustrate what I was trying to say, mag is a motoplat mini6? stock part I assume? If you look closely you can see some Home made motor mounts)
