Rhodeislander
I finally found some time to work on the bike and found it was smelling like fuel badly after sitting. The petcock had fail and the engine had filled with fuel. A lot of fuel. I needed to pull the motor anyway as the rear bushings were shot. I checked the oil prior to removal and it was green? I assume anti freeze. So, i drained the oil/anti freeze mix, and dumped a good amount of fuel from the intake area. Motor is on the bench now.
What should I be looking for for causes?
Fuel
Carb float? is there a needle and seat in these?
Just replace petcock?
Anti freeze issue
bad gasket somewhere?
Lastly, I was pretty upset to find the original issue of the rear bushing slop, was not the bushing. It was the case hole the bushing sits in, not that the bushing wasnt shot as well. Any ideas on the engine case hole being elongated and too large?(Insert female anatomy joke here)
I think i have bit of more than im ready for on the this project...
Bud
Fuel
Anti freeze issue
Bud
