87 WR430 6 Speed - Water Pump Seal Replacement?
HuskyGreg
Well after all these years the seal finally died and I almost burned my motor for an 80 cent part. I assume I must pull the whole side case to do the replacement and will also use a new circlip. Any other tips so I get this seemingly simple repair done in good form?
It is possible to replace the seal without taking the side cover off , if you are lucky.
Take the pump housing off , take impeller off and try to get the old seal out .
You may need a slide hammer with a screw into the seal.
Fiddly job but possible.
If you can get the seal out then the new one will go in .
Grease shaft with waterproof grease.
Make sure the seal spring is facing out so you can see it . [ I have put them in the other way around and it don't work ]
