Mazhasai
Hello, I'm new proud owner of old 95' Husky TE410. But I have some problems with it.
First one: it's hard to start. Maybe i am bad kicker, because it is first bike with kickstart. My technique is to kick 2-3 times with decompressor fully open, then put cylinder on TDC and kick as hard as i can and open a throttle a bit at the same time and pray to petrol gods to make it start. On failure I repeat same procedure. When it is finally started, the difficult part begins - it wont keep idle revs - engine shut offs randomly (may be running for 1 minute, 5 minutes or half a minute). When keeping higher revs with throttle - no shut off. Cold or hot - when i pull out choke lever engine shut off as well. Another problem is with smooth runing - with 1st gear engine runing seems fine, but puting in 2nd gear - it feels like that spark plug is not always working, misfiring or fuel mixture is too rich. I tried changing spark plug, take bike to the workshop to get carb and valve clearance adjusted. It started to start a bit easier, but they could'nt fix issues. I hope maybe you guys, could give some advices what to check first. Greetings from Lithuania
