97 TE 410 engine help.
Shaun Webb
Good afternoon all.
I've began stripping my Husky down as a winter project. (Bought non running)
This afternoon I began splitting the case only to find a lot of metal.
I knew there would be some as the screen was covered in metalic particals.
I've found a nice bent piece of metal but I'm not sure if its part of the engine or possibly part of the big end bearing. Can someone shed some light?
Also,
I have a little rubber piece which I'm not sure exactly where it came from. Can anyone enlighten me? (Pics below)
I thought I'd post this thread just so newbies such as me and others get a rough understanding of just what can happen if you don't maintain your engine.
Thanks
Webber
truth is no matter what expertise about the stray parts is given.....at this point you best do a complete Disassembly and rebuild. (thats no real help sorry) But when you find all sorts stray stuff that came apart you gotta get er apart, inspect and rebuild. Good luck there are a number disassembly threads around about the big single cammers (610s and 410s) Plus the parts catalog found on the Halls Husky website can aid with the exploded views of the engine and chassis components. As well as part numbers for the required fixit parts
Hi Rob,
thanks for your help.
I've stripped the entire engine and i'm in the middle of placing all vital parts.
I've had a look at other rebuild threads and i've yet to see anything which may even resemble this bent piece.
Soon i shall be sending the crank to have the con rod replaced and then hopefully i maybe able to find out if the mysterious piece is from within.
Until then does anyone have an idea or suggestion?
Many thanks
webber
Just a guess, but usually those long stringey/springey stray steel parts are from bearings. Bearing cages or races.
Thanks gents,
I shall have to wait and see.
I e-mailed george at uptite and he thinks it could possibly be a retaining clip. - waiting for another reply.
I explained how all the clips were in their places unless i've missed one.
This piece is pretty hard to judge in the picture but it is about 2.5" in its bent form.
webber
