a little exhaust pop when shifting...
TheRealBuzz
2009 TE450
On the ride into work this morning I noticed just a little exhaust pop when shifting sometimes. It wasn't there before and this is my first ride since checking my valve clearance.
My vales were not perfect but not really bad. Wear was even across all valves and the bike has been running great so I planned to leave well enough alone and work on it over the winter.
I'm sure I've got everything reassembled properly.
Could checking the valves have caused this?
Could rolling the bike to find TDC cause this?
Could a bit of a leak in the valve cover be causing this?
Thanks
An exhaust leak will cause it even if it's a very small leak. Air is introduced in the exhaust stream of a momentarily rich condition when you back out of the gas to shift. You have a small amount of unburned fuel and some oxygen from the air leak plus the temp is high enough to ignite the unburned fuel and you get a pop.
You are referring to a leak in the header pipe connections? This is possible as I also just put on a new heat shield and had the springs off.
Yes especially at the header pipe but it can still do it if there's a leak at the muffler connection. In extreme conditions you can get popping from the fuel re-igniting as it exits the pipe.
Thanks to all for the quick and knowledgeable responses.
I gave all the header connections a little wiggly jiggly to re-seat them. After just a small test ride it's looking, and sounding, good!
Cheers.
