fletchman45
Most of you guys probably know all this stuff already, but just thought I would put my 2 cents in. Picked up a 12 Gas Gas 300 and did the 13 updates. No time to practice went to race entered senior A and got 2nd place! Sounds good right? Worked out a few minor quirks and loose bolts. Nothing strange. Suspension very compliant for stock and not to bad in tight woods. Engine great off idle power runs out on top (Magazine is right I think it is the small airbox) Very easy to start and much easier to start then a Husky WR 300. Mostly due to kickstart lever I believe. Choke on handlebar well liked. Fit and finish not bad. Weak spot. The bike is HEAVY. If you are a B or C rider I don't think the bike being a bit heavy will matter much. Whenever I tried to push the envelope and keep in mind I am approaching 50 years old! The bike would try to control me! Over shooting corners, swapping on whoops. Front end seemed to push a little as well. Again if not pushing the bike it was very enjoyable! Brakes not near on par with Brembo's!! But mostly related back to the weight issue. I bought my bike without electric start already knowing they were a tish heavy . Rear brakes would not work properly with a EBC semi metallic pad so went back to stock but would boil over even with high $$$ fluid. (I do tend to ride the rear brake) So I did what the Gas Gas race team does. Drill a 3/4 inch hole thru the top of the brake caliper. Bingo worked pretty well from that point. Entered race 2. Very nasty race. Crashed numerous times and tired out and again the weight of the bike reflecting when a guy gets tired at all. Backed off throttle rode like a wuss and finished! No trophy. Very sexy looking bike. I feel for a trail bike this bike would work great!! But for and older guy like me that pushes the envelope all the handling shortcomings (mostly related to weight come out!) Grabbed a 13 Husky 144 and as everyone knows. Handling is incredible and PRESISE and inspires confidence!!! 165 kit will be installed for next year. Nagging injusies have held me from riding (most from the Gasser LOL!) The Gasser was LOST in the whoops but nice in the tight stuff! Husky POUNDS thru the whoops but front was a tad stiff so had a revalve. I heard the 14 Gassers are going to lose 9 pounds, but still not sure that is enough. Praise for the engine! it will lug down to about 0 RPM and chug you out of anything and get on the pipe to! Jetting needed work. Needle as lean as it would go and still fat. (Back to small airbox design???) Neither brake as strong or progressive as a Brembo. Ergonomics slim and comfortable!! High end components! Zoke 48 mm fork nice. Plastic material for airbox makes carb removal a little tough. Quite a few different fasteners. Bike feels like it would be long lasting and still looked great upon sale. Again this is all just my 2 cents. No hate for the Gasser just not my ideal choice for a race weapon and for sure faster on a Husky 144!
