Adding Indicators to a 2008 TE
Elliot Tanner
Hi,
First post on here as a new Husky owner. Hopefully someone can help.
I have a 2008 250 TE that I would like to add indicators to. From what I can see it seems like these models come with the wiring, switches and mounting points for front indicators but no actual indicators.
There seems to be 2 pairs of wires (blue/sky blue and red/black/blue) going spare under the dash which I am guessing is the wiring for the front indicators, I have plugged a bulb in to these but have had no luck getting the indicators to work. Is there something I am missing?
Your help is much appreciated. Thanks.
My 2007TE came all ready to ride legally on the street, head and tail lites, front and rear turn signals, mirrors
Believe the 08 model is similarly equipped.
Not near bike right now so unknown wire colors, but can check later
If no one else can get it for you I'll have access to my bike tomorrow evening PT and can get a picture for you
These are left front turn signal wires on '07 TE450
And these the right front turn signal wires...
Each light bulb is wired med blue / light blue.
The right light is wired to that red-black wire and the med blue wire.
Hope this helps
Hey guys,
Thank you for the detailed photos, really appreciated.
I have rigged the indicators up to the wires indicated but with no luck, not even a single flash. Have checked the indicator bulbs on the battery and they work fine, is there anything else that needs checking? The bike doesn't look like much has been fiddled with so I cannot think anyone has removed anything needed. Any idea where the relay should be?
Thanks
