After market handlebar control switch
BobPS
Hi guys,
Is it possible to replace the OEM handlebar control switch on a TE 630 with handlebar control switch from Ducati or other after market switch similar to the ducati's?
Reason I ask is this:
on the TE 630, the horn button on the handlebar control (LHS) is located above the turn signal switch. From bottom up (IIRC) turn signal, horn, hi-lo beam. On my Ducati Monster, the horn button is located at the bottom, the lowest position, under the turn signal. From bottom-up it's horn button, turn signal, hi-lo, and display mode switch.
I want the horn buttons on both bikes to be at the same location so I don't accidentally push the turn signal swith when it's the horn button that I actually want to push :D
Sounds stupid I know... but it happens to me all the time :banghead:
hehe - you should add an F800 into the mix!
I find the horn / indicator switches on the TE very close, I sometimes clip the horn when engaging the turn signals. One interim solution may be to mount a separate horn switch. It would be cheaper and simpler wiring, and with reduced cognitive overlap between the two configurations it may be easier to switch. While you are at it you could replace the Husky horn with something less wimpy (do others also think the OEM horn is surprisingly heavy?)
