WHITEROCKET5.9
what psi do yall usually run and do you run different pressures for mx and hs or enduro type events
thanks
thanks
Tire pressures should be checked each ride. After awhile you will feel the difference.when i checked the other day i had between 5-6 in both. i need to start checking more often.
