Another option for TE 310 Silicone Hoses...
Johnrg
another hose option for 310 riders...
http://www.profactoryhoses.com/husqvarna-tc-te-250-310-silicone-radiator-hose-kit-pro-factory-hoses/
I used this kit on my 2012 310. Fit was good with the exception of clearance to the header. No problems though.
Regarding clearance to the header. Samco that I tried fit too snug. I returned mine and returned to stock. Hopefully they are sized differently.
I have the Samcos on my '12 TXC 310, & yes they are close to the header but after 1 1/2 yrs there is no indication that it's gonna be a problem.
I ordered a set of the Pro Factory hoses in blue for a little contrast and July 4th is around the corner. Will see how they compare fit wise.
I have the pro factory hoses. They fit well and have extra length on the ends to trim to how you want them to fit. They eliminate the t-stat, and I cut the fan switch into the left side vertical run. They do run these tc style which runs through the frame backbone, where the txc/te is ran below it. On my txc, there were quite a few wires blocking that hole in the frame, but I routed the hose through just fine. I have a bunch of rides and so far no problems. In regards to the header clearance, it slightly sits on that little bracket, I just cut a piece of fuel line and slipped it over the bracket.
Great. I just removed, relocated and detailed to prep for them. Appreciate the feedback.
Hoses are on and slightly better fit than the Samcos. I could place the lower hose on both barbs inlet and standoff without distortion. A couple of zip ties, pull it away from the head. Hoses are definitely long enough to trim especially the top hose to pull it back from rubbing the cooling fins. A quick stop at West Marine for 2 more clamps around the temp sensor is all I need to button it up.
All buttoned up and the blue is a nice touch. Oriented clamps so not to interfere anywhere or too close to the radiator and wires. The clamps all need to be on real tight. A small hex wrench, 7mm., works best. The most leak prone area was splicing the temp sensor in as the hose is widest there. West Marine had the good clamps in HD which were a hair wider and fit the fitting well but on initial install fluid was making it's way out so get all tight. Ready to ride..
