Any info on lower or lowering foot pegs for 449/511
Just saying that the Fastways, Pivot Pegs etc should fit fine.....and they can be flipped standard or low.
I am a tall guy (6'4") and looking for more legroom, I bought the fastways and put them in the low and back position. I ended up reversing this, and putting them in the stock position because I felt a substantial difference in the suspension action with them set back. Best way I can describe it is when standing, I felt the swingarm movement IN the pegs whereas in the stock position, I felt the swingarm moving AROUND the pegs. I doubt it is coincidence that the pegs are mounted directly below the pivot on the swingarm. Ideally, you would find some that just mount lower while keeping the fore/aft the same as stock (underneath the swingarm pivot). I don't know of any that are made that way.
With that said, I find the fastways to be vastly more comfortable versus the stock pegs and would recommend the upgrade to those with large feet (I have size 13). Of course if you are a predominantly seated rider, you won't feel the aforementioned effect and all is good.
The Motosportz pegs mentioned above are just lower, not set back: http://www.motosportzhusqvarna.com/Husqvarna TE, TXC, TC, SM, 449, 511.htm
