Any info on this bike ? much appreciated thanks
luke-husky
right im new to the husky game not bikes just huskys i done a swop with my mate and got this bike i believe its a tc 450 ? or isit a te ? also was told 2005 but is this true ?
What size rear tire is it? If it's a 19" rear then it's a TC most likely if it's a 18" then it's a TE or TXC. That is as long as they are stock.
Sorry bin working, it's 5 speed but I think it was kick start ? And had elerictic start put on as I have both ? And as for the wheels I'll have to measure I no there exel tarasago rims I do belive but I though they was standard with this as I have another 450 which had the same ?
Looks like a 06 but the tank is black so it might be a later one. Does it have a side stand lug if not then its a TC.
It don't have a stand but here's a loose spring hanging around down there so don't no if something was on it ? And the boy I got it off said he spent 200 pound on a new plastic kit so don't think that's the original mate ? Just confusing me
I can just see the blue banjo fittings on the oil lines indicating someone has updated to the red plastic. Also the plastic accent is grey not black so another indicator of the 05-06. I would guess 2005 because the forks look like the 45s, a 2006 would be 50mm. The rim size is stamped on the rim by the spokes but you could also just check the tire size as well. 2005 TCs did have electric start from the factory as well.
