guscycle
After nursing a screwed up back and now just getting over this damn flu,I decided to attack this problematic electric start on my '13 TXC 310.
I decided to order the Honda part and give it a try ,especially since it was only $53.70 delivered. I had already noticed the similarities in the flywheels when I had a customer's CRF250X in for an overhaul(I had just installed the updated gear kit when it came in).I also read about it working on the Husky because they both use Kokosun (sp?) ignitions.It is the same diameter in every aspect but the Honda uses a retaining clip on both sides to keep the one way bearing together,Husky only uses one. Question is that it fits snuggly into flywheel bore mainly from the slight protrusions from the clip and I am not sure if the clip could become dislodged-even though there is very minimal clearance between the flywheel side or the cover plate that keeps it in on the other side...any thoughts before I fire it up?The photos are from the original Husky part- the Honda part is identical in all attributes except for having 2 retainers(e'rings)-one on each side.
