Auto decompressor spring tension
Bahr
My decompressor was jammed up slightly and not working, I lapped the hole in the cam and it's smooth now, but I noticed the spring is all loose, like there's no tension holding the decompressor flyweight in until it's about half way.
I assembled it again with one turn preload and tested it on the lathe to check the speed and now the weight flies out at 800rpm. Is that correct? Are you supposed to preload the spring one turn?
I don't remember whether mine had any preload, but let's see:
• Why it may not need that one turn preload: the spring in your picture looks too warped to me and I guess it looked like mine without that one turn; take a look:
With the decompressor mass in either the high revs or low revs position, my spring looks less warped than the one in your picture.
• Why it may need that preload: 800 rpm at the camshaft means 1,600 at the crankshaft, which is roughly the idling speed of the engine. If, without preload, your decompressor starts flying at a speed higher than half the idle speed of the engine, then surely it doesn't work properly and probably you can use that one turn preload.
I think you're right, now I remember pulling the cam from my spare engine which looked unmolested and it was not pre-loaded. I think these springs go a bit loose after time. I ended up just bending it a bit and then it held the decomp on better without a turn of pre-load.
I was initially thinking the same for the RPM, but I think you want the weight to fly out at anything above starter RPM, so then engine actually starts. I don't think it would start very well if the decomp held on all the way to 1600.
Unfortunately the service manual gives no specs, nor info on assembly. I think it best I get a new spring, but they're $50CAD by the time I've shipped it.
Sorry, I got a little confused here. The higher the preload, the higher the revs at which the mass will start flying and therefore we should expect the mass to fly at lower rpm without preload, not higher like I presumed here.
Just to make sure I write something clear and logical, let's consider that:
- if the spring were removed completley, the mass would move as soon as the camshaft spins and the camshaft would behave like there were no decompresor at all,
- if the spring were not flexible at all, the mass would never move.
At the end of the day, those who use a manual decompressor just use it to go past TDC and give the starting kick, right? Then yes, we shouldn't want the decompressor to work up to idling speed and no preload should be safer than one turn.
I agree: they spend all the engine running time in a stretched position and every time the deformation can't be completely elastic and they must warp permanently a bit until, after many hours, it becomes significant.
