grouty
Auto Lover ...
I started to pull down the gearbox on my 390AMX this afternoon. So far, a couple of questions ...
On the end of the main shaft there is the drive engagement dog. The inside of the gear is worn, worse still the teeth on the end of the main shaft are well mullered. How bad is bad ?? To me it looks like I need to replace the shaft and the gear. Are these still available, or is it a question of finding the best used one possible ?
Second ... after lifting the main clutch assembly from the crank, there seems to be a washer missing from underneath it. The manual says there are two needle bearings and a free wheel device. With a washer between the crank and the assembly. Mine is missing. The parts book does not show the number for this ! It only refers to a "gear" of which there is not. Is the parts book wrong ??
I am sure there will be many more questions as I go along.
