Baja Designs KTM Squadron Pro on my 2010 TC250
HuskyNoob
So after some engineering and slight modification I manages to get the light to work on my bike using the stock stator. The light looks almost stock and has held up well the past 3 rides, one of which at night. Ill add some pictures in of the final product.
Could you tell us about what re-engineering you needed to do?
I have a similar bike and I am considering a squadron light for my machine.
Thanks,
Bugs
Looks good.
A little hint...at the bottom of your photo software there is usually a circular arrow going to the left and one going to the right. Try those out before you post a photo. :cheers:
Thanks,
Bugs
Cut the stock stator wire connector off, get a regulator rectifier with a battery to smooth out the current wired to the yellow stator wires. Then find somewhere to mount it all. I used zipties to the frame beneath the airbox. Then wiring new connectors to mate the KTM and Husky connections to work. Then float a ground to the bars along with a switch.
Is there an adaptor to connect the KTM and the Husky connector? or did you have to cut the wires and rewire?
