dualie
My stock gel cell died, so I'm shopping for a replacement. I contacted Ballistic to see if this is the correct battery for a 09' Husky SM 610, but haven't heard from them yet. I believe it's correct, but still looking for confirmation. Anyone know for sure?
Dimensions (Metric): 114MM (L) x 61MM (W) x 112MM (H)
Dimensions (Standard): 4.5" (L) x 2.5" (W) x 4.25" (H)
Negative Terminal Location: Right
Weight: 768 grams (1.7 lb)
Voltage (Charged): 13.6V
Amperage: 15 Pb-eq A/H
Pulse Cranking Amps: 275 CCA
Operating Environment: -18°C (0°F) to 60°C (140°F)
Typical Applications: 1000cc and under multi-cylinder motorcycles and 550cc and under singles cylinder dirt bikes, scooters, and ATV’s.
Note: I'm aware of the Shorai lithium, however, this battery is 160.00, which is 60.00 less, so thinking to get it instead.
edit 2: Ballistic replied... this battery will work. I figur'd it would, but wanted confirmation. This post might help others looking for lithium batts.
edit 3: Installed the battery today. weight savings is 8 lbs and 2.8 ounces.
