Bike locking up , removal of water pump
Kenbeken
Hello everyone im new here and not even sure im in the right place to send a message . I have just acquired a 2006 husqvarna tc450 and it was getting coolant in the oil so I read up on the issue and removed the water pump housing the impeller nut was rusted on and i removed that but when i tried to remove the impeller the shaft slipped out from the bearing about a cm. I couldn’t tell at the time because the engine was still closed up , so being so stupid i reckoned that if it was still ok inside and i turned the rear wheel the shaft would spin but it locked up after about half a revolution and thats where its is where the mistake was made i believe. Is it possible to unlock it by reversing the back wheel im not clued up about engines but im learning fast the hard way hahaa thank you
The water pump shaft holds the upper cam chain gear, you likely pulled it out of the gear and now stuff is binding up. Remove the head cover and have a look.
