millenium7
		TE510 died on me today up a hill climb, tried to restart it and it wouldn't go. Tried bump starting it and not so much as a hiccup until I opened the throttle way open past 50%, then it would run extremely poorly, only combusting once in a while, the more the throttle opened the better it started to run but it was still very sketchy
I only had basic tools, managed to check if the fuel pump was squirting a good amount of fuel and it was. Couldn't immediately see any issues with dislodged plugs or anything but I didn't have a lot of daylight so I just left it as it and had to ride the bike out with the throttle pretty much wide open in 1st gear using the clutch, thought I was going to blow the engine but I didn't have much choice
I had to go back across a river crossing to get out, soon as I hit the water the bike died. So it could very well be a short somewhere. It did eventually start again once it dried out somewhat and I found another hill to bump start on
I havn't booked it up to iBeat yet to check if its reported anything. Any ideas of what to check?
