bike won't start when cold.
nep2012
ever since the winter hit my 2012 te310 will not start unless I push it. Once warmed up it starts no problem. Let it sit a couple hours and it won't start. I noticed the cold start lever keeps rpm up but not a high rev like it used to and it runs rough at low rpms until fully warm. In order to get the cold start lever to rev the engine without missing and rev high I have to twist the throttle a couple times and them the rpm's go to normal level with the choke lever. Could this be a valve adjustment. If the valves need to be adjusted will that effect a cold start?
