blurred vision in 5th
ty w
nice to have faaaasssst again. and with fork clamps down a bit on tubes, it goes right straight over series of pot holes, unlike clamps at top of forks causing high speed wobble. but does this make nose dive in corners, hmmm maybe, i think it might
Pulling the forks down in the triple clamps slows down the steering which added to straight line stability. Nose dive in the corner would be from
too soft a front end, try putting pre load spacers in the tube.
Husky John
hmmm this makes me wonder if someone put longer forks. as fully raised clamps corners nice , no nosedive, but highly unstable and highspeed wobble over pot holes, whilst lowered clamps by 1.5 inches and hands off over poy holes without any wobble, but the front slides out more in corners. a tradeoff
If you lowered the clamps (raised the forks) by 1.5" you are begging to go over the bars... Please make sure that, at full compression, the front wheel is not firmly bottomed into the fender/lower triple clamp. It will stop the wheel right quick and you'll be Superman!
Also - if you have to run it that way to make it stable... something else is wrong! Just some friendly encouragement to keep looking so you can have a safe bike and healthy body!!
needs a spacer washer to fit on top of top bearing so nut is tight to that and not crushing seal. though it would seem tight eanough . original nut gone, found one that threads on , but there many diffrent designs. the original nut had a shoulder to fit inside the seal and be tight on the bearing inner, and the one i found dont have this edge. need to remedy .
