Bypassing oil hose off oil drain bolt on '11 te310...?
DougW
So I went to change the oil on my '11 TE310 today and what a pain in the butt that oil hose that comes off the oil drain bolt. If that hose ever comes off or brakes you loose all your oil. This line goes high up the frame but I have't found out where it comes back out at and goes to.
So my ? is, has anyone installed a regular oil drain plug yet? Have any problems with removing the drainper say?
thoughts?
Hey Doug I have the same question. Always loosening and tightening that hose scares me. What are those engineers thinking? Even a braided steel line with a coupler would be better. Maybe someone will respond. I also need to look at the shop manual.
ya, I'm thinking the first thing that needs to be done is find out the circulation pattern on what all its doing.
Maybe the groups smart ones will fill in the blanks.
It's the oil return for the engine breather. Oil goes into the frame from the breather and gets returned via the sump bolt hose.
It isn't present on the 250 so the factory obviously found some reason for installing this system when developing the 310...
Dave
