Calling Carb Experts
Flash319
I got a 2008 TC 510. Had to put in a restrictive baffle for the exhaust to quiet it down. Seams to run ok but have not had it out on a long run. What should I do if it ends up to rich? Just drop the main or pilot as well? What should I start with.
It should not to be that big of a difference.
the fuel delivery is direct related to a under pressure in the carb caused by the airflow.
idle and low rpm circuit would most likely not effected.
mid rpm can be adjusted with the needle.
full open throttle is the main jet.
you will probably notice a slight change in the responsiveness of the bike.
it is running fine you say?
play with the needle a bit and most likely your done with it.
Robert-Jan
If the carby is set as at factory specs then you should be ok as I assume the muffler is factory OEM and they are tuned with the baffle in.
Always good to run a dirt bike a tad rich-they run cooler
The TC is sold as a "Full Power" model. There is no "power up" setup as Husky calls it. Not sure if the jetting is different between the TE and the TC. I will look it up.
The manual shows the same jetting between the models. Not sure what is in mine now (used bike) but I will see how it goes.
