can i put TC 510 1987 seat/ tank /shroud to 88 model ?
dominique
I am new to this forum so sorry if this question was asked before.
I am considering to buy a TC 510 1988 but i really do not like the look and i prefer the 1987 look.
Are tank, seat, shrouds interchangeable between these models or do i need to change other elements as well?
thanks
I'm not real familiar with the 4 strokes, but it looks like you are wanting to do the oposite of what I did to my auto. I went form 86 plastics to 87 plastics. The problem you are going to have is tank mounts are different. The 87 has a long bolt that runs through frame on the front / bottom of the tank. The frame has a sleeve welded in it for strength. The 88 has two round plastic mounts in the rear, that would have to removed. The front mount is totally different but could be removed as well. Also check the air box and see if they are different. Here is a pic from my thread in vintage restorations http://www.cafehusky.com/threads/1986-430-auto-resto.21749/
You can see all the mounts the top front mount and rear mounts for the 87 2 stroke and the hole in the frame to the right of the top(right) radiator mount is the hole for the 86 2 stroke mount. There is no rear mount for the 86. I had no problems bolting up the rest of the plastic and seat. The radiator mounts were in the same locations. It could be done with some work. Although in my opinion the 88 is a beter design.
