Can Valve Clearance Cause starting issues??? 310txc 13
vara
I recently had a flame out all of a sudden idle.
checked the
  • coil and spark plug, which are fine. (Sparking off the body)
  • Clearance on the exhaust valve/cam seems a bit loose(could that be the cause)
  • I can hear the fuel pump turning.
  • Fuses by the battery
I havent checked the injector and anything else, and dont know what it could be now.
please help
Incorrect valve clearances will make it harder to start. However I feel you have other issues there and it is probably around the engine mapping. Did you just drop the bike before the flame out?
if it ran fine before, you have spark, and it wont run at all anymore.
It is probably the flywheel key being sheared. It makes it spark at the wrong time. You may be able to get a backfire or spit out of it at times, but will not run. Sometimes they don't pop or try at all, but I would still assume the flywheel key is sheared if you cant get it to run at all anymore. ITs pretty cheap and easy to repair after buying a flywheel puller.
When you put it back together clean everything up really well, Use lock tite retaining compound on the shaft and torque properly.
Loose valves don't make it hard to start but tight valves will. If it pull starts but won't kick start tight valves might be the problem.
i Ended sending the bike back to the dealers, when they tell me what the issues were i will send the reply back down here.
