Can't get into 3rd gear?
AllmanFan
Ridding this weekend and my bro suddenly can't get into 3rd gear. Shifter seems really loose lots of play and even stays up compared to mine which always returns to the correct position (as it should). Bikes going in obviously but any thoughts would be appreciated. I posted a question a while back asking if it is normal for the clutch to be so noisy/knocking sound. Most replied that they just have noises clutches. Now wondering if they might be related...? Keep in mind the bike is brand new with only 40 miles on it. 14 te449. Thanks.
Shifter splines maybe, remove shifter take a look, a thread or two about it, hope thats all it is, have not
Heard of tranny problems at all on these bikes
The shifters are notorious for having the pinch bolt back out. At least it's still under warranty I hope.
Probably broke the inner spring and star. Now it will only cam 1s t & 2nd?
Yep. 1st and 2nd are ok 3rd and up, not so much... No return on the shifter. Spring has defiantly sprung. Going in this weekend for warrenty service.
On a side note Tinken... (And please pardon my ignorance) can you explain the differance between getting mapped and or adding a tuner? Once mapped are you always in map mode? With the tuner can you choose the power level you want? Kinda confused. Thanks
