This problem has been getting progressively worse and now I can't kick the engine over at all. If I take the 1st gear clutch off the bike and degrease it with carb cleaner I can get it to kick over when the gearbox is dry, but as soon as I add ATF it just slips. I cleaned out the sprag clutch andmade sure that the dog bones were able to move, but they just will not grip with oil in the gearbox.
I know that this bike has broken some 1st gear springs in the past and dug off some of the magnesium side cover so I sprayed out the inside of the crankshaft just under the 1st gear clutch and got lots of metal flakes out of the end of the crankshaft. I sprayed out the sprag clutch but got no metal flakes. It will kick the bike over when dry, but slips when covered with oil.
Is there a way to get the brass end plates off the sprag clutch so I can get a good look at the dog bones? Or maybe I need to give them more clearance by driving the brass ends off a bit?
I also noticed that the 1st gear clutch drum has about 30 thousandths of an inch side to side play when mounted on the crankshaft. There is one rather thick spacer on the shaft already. Is it supposed to have more than one? That might be some of the rattling sound I used to hear back in the day when I could still start the bike.
One final question. Is there a source for 1st gear clutch springs and the aftermarket 1st gear spring cover plate?
Thanks, Steve
Thanks, Steve
