case cancer
dumpbear
Hello everyone I'm rebuilding my 77 250 cr. I split the case's and low and behold case cancer.It's not to bad the mating surface's are fine it's inside the crank case that has the pit's.My question is what do i use to fill it with that will hold up JB weld? Or is there something better, any responses will be appreciated
The only thing I found is gun coat. Please check with the former Kal Guard company - its split now and they are located in Taylor tx outside of Austin.
Yep its the same coating used on guns - its acid proof , chemical proof. But its not a filler
Checked all sources - talking with the vintage F1 folks they use this on their old mag cases from the 70s inside and out. Its the only thing stops Mag - turning to powder.
Most all old huskys that do not have a coating in the lower crank area but have a patina of old two stroke oil and carbon that seems to seal this area.
So far I have replaced most cases that are too far gone.
I have just assembled an 88 husky with some pitting withing the crank cases - thought it to be simply poor castings. There is a hollow section within the same casting which is filled with an epoxy resin (by husky I assume) its fine so I's say any exoxy like JB weld wouyld be just fine.
I don't think it's an issue, if the mating surfaces are good. Put the motor is put back into service and you will not have any further corrosion.
If it is inside the crankwell, I would use expoxy over JB Weld. If you sand the JB Weld, you remove the seal coat. We used Duro 5 minute epoxy in the 70's to stuff the crank balance holes to raise lower end compression. I can personally attest in that environment the epoxy is extremely durable. 3 inspections over an 8 year time period (constant use) showed no degradation of the epoxy
I want to thank you guys for the info I am going to try some high temp epoxy nothing ventured nothing gained when I get it runnin I'll let you know how it turns out. thanks again.
Tom
