Case half question
Mike82CR430
Does anyone know if a lh case from a 86 wr400 will fit a 1982 cr430 . The part numbers in question are ?? 1619823-01 and 1619688-01 (86)....
Cheers
Mike
The insert at the rear for the swingarm pivot is different. Those part numbers would come with all the inserts even though the inserts have seperate part numbers. Probably would need a custom one, An older one might fit but not all my inserts seem exactly the same outside diameter. I am not a fan on sleeving them down. If you get a case the rear insert has vibrated around then you get into matching the width of the back of the engine. The cases are numbered in pairs and machined as such. The surface for the cylinder might be a bit off, a couple of thousands of an inch or so.
Always a risk using an unmatched pair of crank cases, it is not as if the engines did not vibrate a bit already.
I was more concerned about the shafts lining up and the width of the crank. I will probably weld my existing case half. Just saw a cheap one on eBay. Thought it might be a viable alternative if I have a meltdown. They look similar enough to warrant consideration. I know the 84 models used the same part numbers as the 82.
Mike
84 would be dual shock 12 mm swingarm bolt.
At some point the way the shaft the intermediate starter gear rides on gets an improved attachment mechanism. Probably by 1986, you will see two fastners with 10mm hex heads incorporated into that piece. If your case needs welded because of a kick back and the crack goes through that intermediate point be advised the later ones are at least somewhat improved.
fran.
I got a set of centercases from an 84 250CR L/C to rebuild my 82 430WR engine. They were cheap off eBay and all you have to do is remove the reduction web to install the 430 crank. I think the set I got was $50 and the case set is in excellent shape. You are best to stay with matched case set as you can see from the picture above they were machined together as a set at the factory
