Castrol Power RS Racing 4T
Travis Shrey
Anyone ever use this oil? I did on my last oil change, made for motorcycles and wet clutches. Now when I whack the throttle open in 3rd or 4th gear the damn clutch slips. Are motorcycle oils really that different?
My TE510, SM630, and TE 630 came with that oil out the box and I have done a few oil changes on all three bikes with the same oil. bikes run great with no issues
Yeah, starting to think something else is up. My ride into work this morning I couldn't get the clutch to slip. I never had the clutch actuator rod replaced, maybe it was partially hanging up yesterday and not fully retracting? I guess I should add that to my to do list.
Dunno what oil you were previously using and what it' s viscosity etc was- but maybe it was sufficiently different and that the hydraulic clutch was set for that oil, is that possible ?
I did the oil last oil change, don't even remember what oil I used. Definitely didn't adjust anything for it.
Amsoil 20-50 Synthetic Motorcycle oil. Best there is. :thumbsup:
A motorcycle-specific oil does not have friction modifiers so as to be wet-clutch compatible - JASO rating.
There is certainly nothing wrong with Castrol Racing 4T, however they are forumulated with group III base stocks whereas the premiums are Group IV PAO base stock. It has been argued that group III based lubricants are not a true synthetic. They are not allowed to be advertised as synthetics in Europe, but in the US they are.
Good reading here: www.bobistheoilguy.com
Sorry, it's another 'oil thread'. :D
Turns out it wasn't the oil. I have an adjustable clutch lever on my bike that I set up so that I didn't need a full pull for the clutch to be totally disengaged. I made the adjustment when it was a high of 50 outside, now the temps are in the 80s. That tiny bit of expansion must have been enough to let it slip a little. Backed out the adjustment a little bit and the thing is back to rippin'.
