Chain guide blocks 1978 390
grouty
Auto Lover ...
Anyone know where I can get a pair of the rubber chain guide blocks under the frame ?
Part number 15 15 190-01
Mine have gone west !
Thanks Bill. I have asked the seller for the shipping cost to the UK. I have, however picked up a brand new old stock chain guide block complete with nylon runners, side plates and genuine Husky bolt. Collected it this afternoon, and fitted in 5 minutes. All for the princely sum of £30.... bargain ! What it is to be able to pick up old parts from a supplier on your doorstep.
Glad you found one close to home, the same guy had the whole block assembly a couple of weeks ago for around $30 I should have bought it.
Ok .... time has moved on and the nice o.e set I had are wearing. Much thanks to the granite "sand". I did a bit of research and have machined about 10 blocks.
I will fit a pair this week and see how they fair at the weekend. I cannot believe they are not available anywhere. There must be thousands of ML framed Husky's out there !
The new chain guide blocks have been well and truly tested. I have done about the same mileage as I had with the o.e ones before they wore out. The new ones have very little wear, and seem to be just bedding in nicely.
I have machined the rest of the material and have enough blocks for 24 sets. Supplied with new M5 stainless bolts and nyloc nuts. Give me a few days and I will work out the cost.
Back when Kent was running around on a 360/390.. Eric did away with the bottom block and installed a roller... you can get a modern roller with a bearing in the middle now and replace the bottom wear block.. much nicer... KTM have a small roller with a raised middle ridge for the chain to run on as well.. I think you can get an All Balls one as aftermarket..
