Chain Tension With The Cts?
bbc
Supposed to be about the same more tension less tension I have no idea anyone have an idea?
Hi bbc,
The chain tension is much tighter on the CTS than it is on a traditional bike set up. The husqvarna owners manual states only 5mm movement in a correctly tensioned chain. I personally thought it was too tight and settled for about 10mm.
After the initial breakin (say 100 or so kms) I re-adjusted the chain, but over the following 800 Kms I have not had to change the tension at all. It is always tight.
The other side benefit of a constantly tight chain is the reduction in chain chatter.
It might feel a bit scarey at first to have such a tight chain but it is correct.
What bike do you have ?
Any pics ?
I have the tc 449 I don't have internet besides my phone and I can't figure out how to upload them off it lol thanks a bunch for the insight I will run around 10mm like you said it worked for you it should work for me too!
