Changing a kick only te450 back to electric start. wiring questions
Jornum1
I have a new to me 06 te450. The PO had taken the battery, electric start, ect out to save weight. I am now putting it back in. I have copies of the service manual, but cannon find a good picture or description of where the stock ground cable mounts to the subframe.
Can anyone enlighten me?
The only place the cable seems to fit length wise was to the battery box mount/pivot. I did not have the correct hardware for that, so I used a 1/4-20 bolt and secured it with some nylon insert lock nuts. So i just put another nut in between the subframe and plastic to secure the ground. I am sure this is fine, but I am curious where the intended location is.
Thanks in advance,
Jay
If it's the same as my UK spec '04 then the ground cable mounts directly to the bottom starter motor mount bolt.
Hope this helps.
Edit: it does sound like yours may be a bit shorter though.
Thanks 7 point,
Yeah mine was only about 6" long. But I am not even sure what bike it came off of. I bought the parts off a ebay vendor. Either way, my mounting location doesnt seem to be causing a problem. I may get a couple lugs and make my own similar to yours.
Any US spec 06 te450's out there care to chime in?
