Changing the hole engine.
Sven
Long story short:
Blew up my head and bought a new engine cheap to rob the head off it.
Turns out the new engine is an 06 and my bike is an 05 (TE) Doh!
The head wont fit. There are lots of differences inc Head design (obviously), shorter piston/longer con rod etc etc.
So I'm gonna change the hole bloody engine now. Is there anything I should be wary of? Ie The 06 engine runs different so carb needs fetling. The gear box is taller so you need different sprockets????
Much love
06 is an improved engine, stronger valves, better clutch. They are basically bullet proof. I would just plok it in and try as is without mucking around with gearing initially.
