Odd... The cylinder and piston completely seperate, then come back together... There would have to be some tight tolerances on that sum-bitch... And I don't see how the cylinder/piston stay parrallel while it's spinning, but then again, I didn't invent it. Neat concept!
Would be a distaster if it jumped timing.
It also doesn't have any sort of an exhaust system/muffler.great concept! The video that shows it running was interesting. A lot of parts but no battery,radiators & other things would be very different. Sounded loud! But probably depends where the mic was
the exhaust vents right into the engine case which in this example has no cover installed. Notice there is also no oil? Ceramic pistons and cylinders and no contact mean almost no friction / heat other than the combustion itself. Very interesting.
Interesting, but doesn't it seem like you would be wasting energy by moving the mass of both the cylinders and the pistons?
And the amount of rotating mass is huge. And how do you deliver the fuel with everything rotating around like that? Seems like an overly complex, inefficient design, although being so different, it's kinda cool.
