Cleaning engine case?
dobr24
Ive got streaks on the cases from coolant and oils. Anyone got any suggestions how to clean them up?
Is it on aluminium? I should not even mention this stuff but... Body shops use this purple acid stuff. I have known people to mix this stuff 1/3 acid 2/3 water. It will take a clay stained cylinder and make it look new again. While washing the bike and the water hose out spray this stuff on and count to 20 and hose it off good. The big problem here is I do not know what it might do to the aluminium over time. It is not for painted surfaces and only for aluminum.
sounds like an akaline solution,some of the cleaner/degreaser products sold in stores will tell you not to use them on aluminum for that reason they will etch the metal if they are not rinsed off quickley and will change the way that the metal looks.
as raisrx251 said u can use a acid aluminium cleaner but it will make all the unpainted parts rust.. wd40 will do the job a bit harder then the acid but a lot safer in my view,i spray it on and rub it with just my hand or toothbrush .....
