Luke Ballard
Hey guys.
So I got and installed the correct springs for my weight 6.7 eibach rear and .54 racetech in the forks.
Much better straight up, but now I need to dial the clickers in. Now I have the workshop manual and have just gone and reset the clickers all back to the standard factory settings so I can play with them from there. This was easy with the forks but I'm confused with the shock.
The manual says to "reset the standard setting, turn upper adjusters clockwise until reach- ing fully closed position. Then turn them back to the above-mentioned positions" (16 +1/-2 clicks shock low damp speed and 1 ± 1/2 turns for shock high damp speed, 16 +1/-2 click for rebound).
As I said the forks were easy as they say the same as above but the recommended clicks make more sense...
-10 clicks compression and-14 clicks rebound.
Can someone please explain exactly what the +\- and 1/2 clicks are all about?
In all, I'm looking for a smoother feeling fork at high speed desert type riding, on hard rocky stuff with deep sand sections with good smooth action on the drops and table tops. With the rear, I want it to be firm but not so harsh that it kicks my feet off the pegs or springs and pops up under me when it hits unexpected rough stuff. As I said though, I'm just trying to get the clickers back to the standard factory settings and work from there, just can't work out the shocks standard settings.
Any help appreciated!
Also, whilst I'm here, I must give a huge thumbs up to the P3 carbon heat shield I put in the header pipe... Awesome!
The Force radiator braces / guards have paid for themselves twice already after 2 decent " get offs" that should have caused some sort of radiator damage, but are still 100%!
Not so impressed with the ego bark busters as they are impossible to fit with the bar mounts as the clutch line gets in the way. I moved the line up and the bark busters sort of mounted below the line, then first ride, a little
get off and the guards spun up and sheared the clutch line off! New clutch line installed and bled and now looking for a solution to the mount the bark busters. Can't seem to get the clutch line out of the way, doesn't look like the triple clamp mounts will work, bar clamp mounts seem very pricey and not 100% sure they work with the strange standard husky bar clamp setup... What to do?
