Clutch just went out?
brandontx
So I just got an 08 510 SMR and it only has 200 miles on it. The clutch went out this morning. The lever just pulls to the grip and nothing. Going to check the fluid but it feels like nothing is in there. Looks like some oil is coming out where the clutch cable goes into the bike. Found a few drops of greenish oil on the bottom of the frame dripping off. Could this be a slave cylinder problem so soon? :excuseme:
if you don't see any fluid evidence yet the master cylinder is getting lower its your slave piston seal bypassing fluid, this is and has been a very common issue.
But wouldn't that leak into the bike and not on the outside of the bike.
yes the slave leaks into the engine, if you dont see any evidence of leaks externally that is is your culprit. It is a simple sealed system.
I noticed a lot of threads regarding using the 7602 racing piston to prevent and cure this problem. If the slave cylinder isn't the problem I would like to prevent it from happening.
