ken510;132182 said:Is anyone is running a ZipTy slave/7602 piston-x-ring combination?
I was just curious how many miles you have and how it's holding up?
Any comments would be greatly appreciated.
schweikert;135472 said:Where can i get one from?
EVOXBOBBY;135638 said:And if it were a leak why does my bike run perfect for about 10-15 minutes then I have no clutch pressure? A leak always leaks. Not 10 minutes after you drive. There is always pressure in that system. I should see fluid below my sprocket on the frame...... And faint traces on the floor.
We have lots of customers running that combo in their bikes. Almost everyone is having great results with this setup. We have gotten a few reports of this combo not sealing correctly, or leaking. The bad reports seem to be coming mainly from the first run of pistons manufactured before August 2009 and early run of slave cylinder. We tightened up our tolerance on the second run of pistons a little for better sealing so it should be taken care of now.
