Coil mount broken!
RossmcG
After so many problems, I removed the coil to find this half of the mount broken, does this equal electric start very slow and and unable to start? The earth down to the starter is bolted on that side, the coil is bolted to the frame from both sides so will the earth be weaker if one side is broken?
It all seems to have sorted itself out, I need to replace the hard stop nut as it seems stripped and not locking the bolt in position for very long sot tps is always changing! My starter is faulty even with a full battery and I need to get my head around the brake lights ( not working)
Thanks!
