Compression Testing & PSI
hilz129
Curious what a typical PSI reading should be on a vintage Husky using a compression tester. I just bought a tester and want to give it a try before I take the motor down and inspect it manually. I've heard numbers anywhere from 125-150LBS is a normal range. Not sure if the bike specifics matter or not, but if they do, my Husky is a 1979 250WR. Any help would be appreciated. David
I think it should be higher than that. My 83 250 runs about 160psi and my 430 about 180psi. But there are so many variables including altitude and how hard you kick, not to mention the gauge itself. About all you can really do is build the motor correctly and get a baseline when it's new and broken in, then watch the readings over time to help gauge when it's time for a rebuild.
I did some research on proceedure to confirm what I have heard about having throttle wide open during test. I did find an article supporting it so it does make sense
You can't push the PSI as high on an air cooled bike as you can on a water cooled, but I think there's more power hiding in those Can-Am's!!!
