TYTE250;31613 said:I was changing the oil on my new TE250 this afternoon and noticed that my coolant reservoir is bone dry. I checked it both hot and cold and its still empty. Is this OK? BTW, what type of coolant is everybody running?
TY
Better take a peek and make sure that's full when you go to fill your reservoir. I've heard that you shouldn't use regular automotive coolant. It can get kind of gelled and is rougher on waterpump seals than stuff designed for bikes. I am trying some coolant made by Motul. I'm sure lots of folks here have their favorite coolants. Like oil threads, coolant has been discussed on this website a few times.
that's for sure.......maybe more like 'blow' a hole thru. In the right conditions, that nasty hot coolant can easily over pressurize that small dry tank causing it to burst with a big pop. I remember seeing a vid of just that happening to someone of a Husky, but can't remember when/where I saw it.Motosportz;31628 said:Make sure you fill that sucker up about half way before your next ride. If not and you over heat the steam will burn a hole in it. Seen it with my own eyes.
TY
HUSKYnXJnWI;32035 said:The blue stuff that comes stock is made by AGIP. Apparently you can get it from BMW and Lambergini dealers- if you like blue- do as stated and keep Engine Ice on hand.
fidollaz;41970 said:who stated "keep engine ice on hand" and why??
Only keep "Engine Ice" on hand...if you are running "Engine Ice"
They are made to be mixed with "H2O" as per instruction on the container. Will not work at 100% unless it say to on the bottle "Premixed"why not run 100% engine ice?? or 100% g12?
That's what you're suppose to do.anyone mixing distilled water at some percentage with the g12 or engine ice?
(see quote below)from the engine ice web site:
"Can you mix Engine Ice with other products or types of coolant and antifreeze?
This is very good advice.We recommend you never mix ANY TYPE of coolant and antifreeze products. One reason is that propylene glycol and ethylene glycol do not mix well together. Another reason is that just because the base fluid may be similar, other additives and ingredients may not be. Just as you would not mix oils, and for the same reasons, you should not mix coolants and antifreezes.![]()
krieg;41976 said:Engine Ice should NOT be mixed with H20! The label clearly states this.
Engine Ice Hi-Performance Coolant is premixed with de-ionized water to protect your water cooling system from scarring, scaling and to effectively provide "prolonged optimum operating temperatures."
People apparently confuse the Husky "overflow" tank with the conventional coolant "reservoir" found on cars. In practical terms, an overflow tank on a 2T or 4T motorcycle should be considered a "surge" tank... or somewhere for coolant to flow (other than the ground) when things get too hot for the radiator to handle. As a former Pumpkin bike owner who's bikes did not come with an overflow as standard equipment, I can vouch that there is a HUGE need for an overflow tank on most bikes (if not all).Jrmobb;42334 said:my reservoir is empty. when i ride slow single track stuff ive overheated it before and the reservoir fills up a little. after a few minutes it is sucked back into the radiators.
