Counterbalanced
old3
Anyone know if they span all years and displacement from 2004-06/07 and 250/450/510? I found the one pictured.
verify P/N they are different for 510 and 450 but get into the parts fiche they are listed in there. you need the bearings and the 2 drive gears. my suggestion after remove the flywheel disc and aligning and installing (press fit/interference fit) the gear onto the crankshaft weld the gear on so it cannot slip under any circumstance, no worries for the C/B shaft if I remember it has an index or no slip keyway. we did 4 small welds then cleaned them up on the crankshaft. also make an alignment tool with a cut off drill bit shaft that fits into the alignment hole on the drive gear and mates to the crankshaft.
Yes, I agree. I had three 2006 450s back then. One of each type and the SMR was so much nicer. Shame they didn't CB all of them.
Thanks for the help!
I never had more than four. I thought I was out in 2010??? When I finally unloaded all my scraps of what had been three 450s. And I had always advised others from ever buying one from the 90-2013 era but when I saw this minty TC just like the one I owned nostalgia took over and here it is.
So I find myself once again with a not great MX bike that I can't unload even though it's almost new and not a bad Enduro if your not in a hurry compared to the new stuff.
I have a new FC450 and this 06 and I'm thinking I'm stuck with it so better prep it the way I'd want it and just use it for off road stuff. I plan to be cured from Cagiva built Huskys after this one. Seriously. No, really, I've learned my lesson. I have! Lol! The bikes I hate to love.
After the WR250 left, is still have a CR125, WR125, TE250 TXC310 and an SM610 with extra DS wheels.
I'm too far gone to redeem!
