cr250 kick start problems
hi re-building a 1982 cr 250 .
  • gearbox
    Votes: 0 0.0%
  • kickstart
    Votes: 0 0.0%
  • Total voters
    0
  • Poll closed .
john jones
hi re-building a 1982 cr 250 does anybody have a photo of the complete left casing after removal of cover .stripped because clutch and idler gear had broken teeth gear seems to have jammed on each other. should the pawl be rubbing on the kickstart gear all the time?any help would be good thanks
Do you have the half moon looking steel retainer bolted in the clutch cover with the 2 screws?
That holds the little spring loaded paw back out the way until the kicker pulls down a touch.
